calipace44
New Member
- Joined
- May 1, 2014
- Messages
- Reaction score
- Location
- United States
So got myself a crazy idea that I want to live on the water for last
summer or about. and went and traded my friends truck for this 64
Pacemaker 44 on craigslist.. had a prepurchaise survey done by some
guy on craigslist and it showed that the hull was sound other than
some soft spots around windows and on deck and some termites eating at
plywood roof over the bridge.
the engines were rebuilt several years
back. they are chevy 454s
after reading here and on the defunct
pacemakersownersclub i pulled the trigger last june. Im in so cal, so
that was still several months and for the summer and good times was
had. mostly as a harbor apartment. I work nights so not a liveaboard,
but ayways. fun times. and my friend whose truck i traded for it works
in marble and stone. so we put in the new marble kitchen counter.
Original kitchen
Working on it with my friend
Finished version
I did notice that the boat would expel water daily as it was coming in
pretty fast. I did know it needed bottom paint so come fall i decided
to investigate
ta da da duh
it did need bottom painting so after trying to find a yard that would
take her up to paint I found one that would do it without a full
survey and had a rail cart. well, after negotiating for bottom paint
and agreeing i took a trip down. about 30 miles.
well it was kinda going ok at 8 knots but come 10-11 it began to shake
quite a bit so i slowed down and well, we did get here and once out of
the water the yard manager said he was surprised it actually got there
in one piece as the shaking was caused by the port prop pulling the
rear strut away from the hull. the strut base electrolytic ally rotted
off. also the keel bots were all bonded together. as electrolytic
bonding is a pretty bad idea for a wooden boat it made the boat ino a
battery apparently. which in a wet environment causes the bolts in the
keel wood to become battery cells. which electrically corrodes the
wood around them via galvanic delignification.. apparently the boat
hasn't not been out in about 5 years by the look of it. so the gardboard
was pulling off and another plank came kinda loose and it leaked from
shaft seals. oh and there was a bunch of creatures living in the keel.
so they had to be burned out and all that had to be cemented.
but they said engines were in excellent condition
rest of the planking was solid, seams were ok, interior was ok
so i had them fix all that
except the strut
they wanted 4 k for a new strut, and it would take couple weeks I
decided to just fix the rest and take the strut out until the next
time
because all I wanted the boat was an apartment on the water.
and after I spent 7 k on fixes and painting I decided to take a look
around the boat as to where I could fix some stuff myself
so there
I decided to investigate the soft spots at the corners of window frames.
and boy did it go
So after finding lots of rot around the front outside bench and the window corners in the salon I decided to remove the bench and rebuild it.
After removing the old rotten wood on the bench I discovered that the rot extended into the corners of the salon window frames and rebuilding the bench became not as important.
Apparently the previous owner thought it would look good to cover the frames with shiny stainless steel corner angle iron from top to bottom the wood was soft and I was left with some termite holes and lots and lots of ideas
So I Cut all the damaged cabin side frames and ply and was left with this
Long lines were me playing with a router looking for termites. no termites. all solid. filled with with aerosil / epoxy
So the window corner frames and window channel rails were rebuilt with mahogany covered in cpes.
the empty spaces left were assembled in place from 3-ply 3/8th plywood and that was soaked in cpes before all the cutting. The inner layer was installed, covered in epoxy, outer layer screwed into the inner, once all good and solid the screws were removed and everything coated in epoxy with all the holes filled with thickened epoxy. then I fiber glassed it into a single structure.
I ordered replacement window tracks from Beckson. While waiting for that I removed the floor flashing right by where the cabin sides meet the deck as I found them to be cracking, soft and nailed through into cabin sides. underneath I found cracked, brittle, damp (we just had 2 weeks of rains) cement of some kind that came out in long chunks and some soft wood right by the seam. Nothing major, but it seemed like it was cold / damp air was raising through all kinds of little holes.
so I dried it all off for a week and filled it with thickened epoxy and fiberglass fibers
My next step is to create a filet right over the filled seam and fiber glass a 4 in wide tape the whole length over it.
I read that was what people did with success
Also a lot of paint on the sides was cracked and I sanded it all off. a bit aggressively
then i covered everything with neat epoxy
So I have questions. Please do consider that I bought this boat to have as my apartment on the water. I work nights and not far from Marina Del Rey, so as such it’s not a bad prospect. However, it's not going to be a Newport Beach Parade show boat.
So my first question is about fairing this
I have two ideas I gathered so far
a) fill with thickened epoxy / fair / prime with bulls eye 1-2-3. cover with rustoleum oil based enamel
b) prime over with 1-2-3, fair with evercoat z-grip and then paint with rustoleum
I have epoxy and rustoleum and 1 2 3 and bullseye.
I also read great things about Behr porch and patio for above water painting in dry so cal climate
A second question is this
On the starboard side, when removing the cement from the seams and knowing that there was more damage to the corner I found that some of the planking was damaged and the previous owner basically filled it with some sort of a yellow patching material / cement. The side felt cold to touch and after i removed some of the pain I found that. so I removed it all.
You can see bulkheads and frame. I let it dry for a week and then soaked it all in cpes. Now I need some ideas here too
My vague idea now is to square the "wound", dutchman laminate some layers of ply in epoxy and the glass and paint.
I'm planning on painting the whole thing, deck and sides, so this repair should be able to do the trick.
You think?
Thank you!
