the brain
Senior Member
- Joined
- Sep 3, 2016
- Messages
- 440
- Reaction score
- Location
- Alabama, home of college football champions
no I came up w/ that on my own.Did someone tell you polyester resin sticks to varnish?
Note: This feature may not be available in some browsers.
how about just the varnish and large exterior type carpet for protection?If you are fiberglassing over oil and varnish, it won't work.
3/4" 7 plyHow thick is your marine plywood and how many plies does it have?
I'm open to suggestions this was suggested "PS1-95" grade but what is it where can it be obtained Unknown to me.
When coating plywood (or any porous surface) you'll need enough to do three coats, including all edges, holes, cut out and sides. Typically you can expect 300 sq. ft. of coverage over a porous surface, like the raw wood coat on plywood, per gallon. Maybe 20 - 30% more on previously sealed surfaces.
The label on the right is the one you're looking for. Note the "PS1-95" grade I previously mentioned. This is still the redheaded stepchild of plywood, but usable in some applications. Notice the differences in the label, the right one says "Exterior", while the left side shows "Exposure 1". This is the lowest acceptable grade you should consider (Exterior).
