Hello everyone.
I'm new to the forum, but I'm not new to the world of polyester or naval design. However, some of you seem much more knowledgeable than I am and offer excellent advice.
This topic might also be of interest to some of you.
The story:
I stumbled across an old boat mold and bought it on a whim. I think I got a good deal.
For now, I've just given it a good pressure washer and turned it over to inspect the bottom of the hull, take my measurements, and plan future designs.
The boat is 8.70 meters long and 2.70 meters wide amidships. It's relatively low, 1.35 meters at the bow, but its lines are correct.
I therefore want to put this mold back into service and use it, not industrially, but several times. So there's work to be done.
My problems:
The foam reinforcements are quite worn.
First of all, the exterior has been very poorly maintained. After a pressure wash, the fiberglass looks like it's fraying, as if the polyester has evaporated from the surface.
Inside, the gelcoat isn't too bad, but there are still some cobweb-like cracks.
The foam reinforcements are quite worn and there are numerous breaks, but more importantly, I find the mold relatively thin.
My plan of action:
So I'm going to take this mold back to my shed and start by re-coating everything with polyester, for free, repairing all the broken structures and then thickening everything with 3mm Coremat.
Then I'm going to turn the thing over, repair the cracks in the gelcoat, sand it, wax it, apply PVA, etc.
My questions:
Does my plan of action seem logical?
Do you think my new thickened polyester coating will adhere easily if the surface isn't too dirty?
If not, I could try sanding everything with 60 grit, but I'm afraid I'll remove a lot of material before I reach a truly "healthy" area.
Do you also think the cracks will reappear quickly?
The story:
My problems:
My plan of action:
My questions:
