Resurrection
Junior Member
- Joined
- Apr 14, 2017
- Messages
- 19
- Reaction score
- Location
- Rhode Island
Gentlemen,
Hoping to get some info and ideas about how to aproach what is almost an entire rebuild of the stringers, transom and deck of my Dad's old 1978 19' Cape Codder without using any wood (at least under the deck).
I cut out the floor, removed all of the waterlogged foam underneath and all other soaked wood, then cut out the inner skin of the transom and all of it's old rotted wood, and pried the wood out of all 5 full length longitudinal stringers after having cut off the top edges ( the glassed-over 2" plank had mostly seperated from the fiberglass).
So I'm left with a clean inner hull with the skins of the old stringers remaining.
My thought is because the stringer skins themselves still appear to be well bonded to the hull, having been laid out solidly when originally built, that I could still use them structurally, so long as they can be reinforced with an inner Fiberglass lattice which I would hand-lay, or filled with a structural element of some kind.
I'm also trying to think of a way to use 4" or 7" thick DOW extruded polystyrene under the deck as lateral structural members as well as safety floatation.
However I know there's a problem with trying to fiberglass over this material, but I like it for safety floatation because it won't absorb water unlike the blown-in foam that was used before.
Any thoughts ?
Joe
Any thoughts ?
Joe
