the brain
Senior Member
- Joined
- Sep 3, 2016
- Posts
- 446
- Reaction score
- Location
- Alabama, home of college football champions
I was only able to reuse one it's on the port side the other had rust stains.
I've been using a 15 gallon rectangle 15 gallon stuffed back agaist transom on starboard side. an reserve 6 gallon tank stuffed on transom port side. no listing problems but I want to reduce stern weight.
I have a chance to obtain a 31 gallon saddle tank it's longer and wider than the orginal 15 gallon, techically it's imperial gallons.
I'm thinking since the vessel sits w/ bow up higher than stern the fuel would sit diangley so the majority of the weight would still be aft.
or could I cheat physics an install the tank higher aft. basicelly leveling out the fuel in order to keep weight off stern.
additionally can I expect to be able to put X amount more fuel in the starboard bigger tank than the orginal 15 gallon. my helm station is on starboard so is a bit of tackle, an start battery more than I have on port side.
I like to gain deck space but the main priority is reduction of stern weight to get a heavier engine.
I should mention the inboard has been converted to bracketed outboard
here's my older thread on this subject minus the new 2nd saddle tank.thanks ahead of time for advice.
33 gallons aft of midship creates a lot of stern weight 231LB? https://www.boatdesign.net/threads/33-gallons-aft-of-midship-creates-a-lot-of-stern-weight-231lb.63366/
