tom28571
Senior Member
- Joined
- Dec 12, 2001
- Messages
- 2,474
- Reaction score
- 117
- Location
- Oriental, NC
Tony,
On the steering issue: When a boat with a very wide transom heels the hull shape in the water can change drastically. The axis of the hull changes from the centerline to a line from the leeward transom to the bow. The leeward immersed stern also lifts and causes the bow to go down which can introduce bow steering issues. This can get much more complicated and is not always bad but, on a first try, should probably be avoided.
Wide sterns are used on many boats but they are generally high performance ones with traps or racks and other means of keeping the boat flat. They may also accept some loss from the above problems in favor of high speed planing with only the aft part of the hull in the water. Not the cute little boat your wife wants or would even be caught out in.
Paul, The comment on fat refers to the second set of numbers Tony introduced which are considerably fatter than the first set.
