What I had in mind was to reinforce your tapered thinwall birdmouth wood or structural foam mast with pultruded carbon rod or strips capped with a biaxial sleeve which could be glass or carbon. The advantages are the pultruded bits have far greater physical properties than any wet laminated structure so less is needed and it is easy to taper the strips up the mast to optimize material usage. The rods I had in mind were ~ 2-3 mm diameter and came as a continuous piece in a roll. The sleeve over the rods fix the strips in place and prevent buckling and I suspect help help transfer shears around the mast.
Edit: It took me a while to chase down this info, my memory not as sharp as it used to be. Graphlite Carbon Rod by Jim Marske https://www.ihpa.ie/carbon-dragon/index.php/home-top/articles/83-graphlite-carbon-rod
Okay, I didn't get it previously, but now I do. This sounds quite crazy, but it could work. However, I couldn't find any pultruded carbon fiber in rolls either on Ali, Ebay, or any EU sites, apart from a few that only deal in bulk. Do you know where this stuff is available?
Off topic, for those of you who enjoy horror, my dad took a photo of me sailing with that current carbon mast today. This was in around 5 m/s (11mph) of wind. I can only imagine how fast this boat would be if that mast didn't turn into a bow... I have to sail her with pretty much zero downhaul, otherwise the mast would bend even more due to compression.
EDIT: Also, gaze upon my improvised mast un-bending jig. Leave it overnight like this, and the mast is straight again, good for another 2-3 hours of sailing before it becomes like in the pic above.
