You may be right about maintaining the higher planning speed. In the 3 2hr break in motor tests I ran, I had to cover a lot of other questions, and as most hulls surge when coming on plane, an accurate mph tipping point between 14-20 has to be nailed down better.
These were very rough conditions, ran at high speeds, and the hull ran very stable considering conditions. She was wet, taking spray over the bow and top of the cabin, and getting her bow up a LITTLE more will help, And frankly, it it was anywhere this rough the boat would have been coming in, not going out, with a lot less spray in a following sea. The previos 2 tests in 2-3's were flawless.
The hull bottoms are flat, with a 9" wide flat planning pad, and because the sponsons are a little narrower than common, her entry is slim while not knife sharp at the tips of the bow to allow removing all air bubbles in the glass easier during layups.
So IMO, the problem is to make her 25% lighter to allow to:
more room between the water and tunnel top in the stern to avoid blocking off the tunnel when I tilt the bow up a little more
Tilting up move the bow spray back closer to mid ships to make her dryer on board
Decreasing vessel weight will get more fuel carrying capacity for longer trips offshore
Get her speeds with this power from 45 to 55 mph and increase her fuel economy.
Fuel economy is currently using about 190 lts in 5 hrs, key on key off, running hard with twin 225's averaging about 19 mph. I will get the gauges programmed to read these during tests on the next hull, but I am encouraged by the rough estimate so far.
Some anglers in the east and southern US now want a 500 mile range and to be comfortable during long trips cruising at 40 mph in seas and these are fairly demanding conditions for a day boat. As it is now, I can do this in 2-3's sitting comfortably in a cabin with my hands off the wheel and making high speed turns with lean in, so except for the bow spray and load capacity of this very heavy layup in bad conditions, I am almost where I want to be and less weight and getting the bows up slightly will increase my range and sea worthiness in 4's instead of 3's, markedly, in my experience.
And as the hull is very solid going fast in rough conditions, I am confident that she will also last with a lighter layup with 7 skins on the sides and 9 on the bottom as opposed to 16 using much heavier roving with larger overlaps and a higher percentage of resin as was employed on this learning experience.
So thanks again for your tips, they have helped me feel better already.
