Hello Shaury and welcome to the forums.
I would recommend that you find your way to a Sams Club or if that is not an option to an O'Reilly Autoparts store. Both of these retailers stock batteries made by East Penn Manufacturing. East Penn is my go to manufacturer for high quality AGM batteries. Sams Club carries a brand called Duracell, O'Reillys are called Superstart but they are all the same and made by East Penn. Just a different label on the battery case. If you're curious about East Penn.....
www.eastpennmanufacturing.com
If you decide on AGM's I'd discourage buying Optimas. They were great batteries years ago but they moved their manufacturing out of the US and are no longer what they once were.
Whatever battery type you choose, use the same chemistry for both start and house batteries. If you choose AGM's use all AGM's. There is nothing wrong with flooded lead acid batteries. I've just found that good quality AGM's last longer and I like the no maintenance aspect. Just choose a size appropriate for your big block. I prefer The Group 31 size for the house bank (I use two) but that decision will be up to you.
I can tell you that I have three Duracells in my boat that have provided trouble free service for the last 8 years. They still test at about 80% of their original capacity.
If you have a few dollars to invest in your boat I'd recommend removing that "1-2-off" selector switch. A much more modern solution is a simple "on-off" selector wired in conjunction with an automatic charging relay or ACR. This arrangement "idiot proofs" the battery selection process as it is simply an on or off proposition. The ACR disconnects your boats battery banks when there is no charging current present. When you start your engine or engage a battery charger the ACR reads that there is charging current present. The ACR then connects both batteries so that both receive a charge. You can even add an indicator light to your helm panel. I have a green LED installed at the lower helm on my boat. When I open the cabin door, I just glance at the panel. When I see that green light I know my charging system is working properly and both banks are getting a charge.
https://www.bluesea.com/products/7610/SI-ACR_Automatic_Charging_Relay_-_12_24V_DC_120A
Undercharging will kill a set of batteries faster than anything else. It's important to keep your batteries fully charged and not to deeply discharge them. If you typically just go out for the day the OE alternator on your boat will be fine. Pick up a good three stage battery charger that you can hook up at home and your batteries will last you for many years.
You'll hear many "experts" say that boat batteries won't last more than three years or so. That is complete nonsense. Good quality modern AGM's can easily last a decade or more IF THEY ARE PROPERLY MAINTAINED and not abused (deeply discharged). Good batteries are expensive.
Good luck to you,
MIA
