Glenn Shelburne
New Member
- Joined
- Jul 12, 2023
- Posts
- Reaction score
- Location
- Indiana
I converted the above boat into a CamperBoat. Using RV method of sandwich sidewall with aluminum frame. I guess you could say it's over engineered. In my calculations I didn't take into consideration the amount of weight added with interior items. It floats a little lower than I would like as it is designed to sleep 4. The Tracker Party Express is a fiberglass tunnel hull construction. With the tunnel fairing to a full transom. I have purchased 4.5 inch thick foam the same type that life jackets are made from. So in calculating the 40" x 10' x 4.5 I seen this as a 650 lbs buoyancy gain. As it will be below the waterline in the tunnel area. I have attached the foam to the hull and covered it with 1/8" fiberglass sheet material which is bonded together with 3m 5200. There is little room for water in this area but I don't want it to be there if I can keep it out. This type of foam will never be waterlogged. My question is should I just caulk the edges and call it good or fiberglass the sheets to the existing hull. I have worked with fiberglass and gelcoat before so no biggie. I just wonder if I'm overthinking or over engineering it. The boat will be on a canal with a speed of 10mph. Photo attached.
