Note: This feature may not be available in some browsers.
I understand what you say about fitting a spray rail, what do you mean "angle them slightly" ?
Nothing to do with water separation at the chine, I cited two separate examples of planing craft that have immersed vertical surfaces that aren't contributing to lift, they just add to the wetted area, and therefore increase drag, they were a sea-sled, where those surfaces are on the outside of the hull, and the "split" box tunnel hull where they are on the inside. The idea was to have those surfaces out of parallel with the direction of travel, so they tapered slightly, and hopefully no longer touching the water rushing by.
I am talking about planing speeds of course, when the penalty of too much wetted area really kicks in.
Planning speed !! so what kind of speed is that ??
10 mph 30 mph 50 mph 70 mph what ??
where and what speed does skin friction against the waters surface become a problem ??
does it start all of a sudden or is it a gradual thing ??
have you ever water skied ?? fastest I ever been was 60 mph !! in a straight line![]()
you could check out my photos of a hull you described at members site Rick Gray or at design siteImagine a hull like a basic sea-sled, with parallel, flat, plumb outside surfaces, running along at speed. All the displacement of water is taking place on the inside hull surfaces, but there is wetting of these outside panels that is retarding forward progress by skin friction. My question is this, what happens if those panels are not parallel, but are widest apart at the bow, and nearest at the stern, if only by a few inches ? At what speeds and negative angles will water no longer contact those slab sides, and thereby free it up from unwanted drag ? Might look odd, but who cares.![]()
