PAR
Yacht Designer/Builder
- Joined
- Nov 12, 2003
- Posts
- 19,126
- Reaction score
- 508
- Location
- Eustis, FL
Having punched up some math for the problems with this idea, a few conclusions have cropped up. The biggest, as guessed is weight, by as much as 152% (depending on pipe diameters and filler needed) heavier then a solid laminate, using the lowest density foam and thinnest sheathings possible. Using typical schedules for layup, near twice as heavy as a one off single skin and even over the heavyset of chopper gun jobs done in the early 60's. This clearly isn't good.
The puncture resistance is lower then single skin, the cost is much higher, unless the PVC is free. The structure will have great longitudinal stiffness, but not much else without additional structure.
If the additional cost could be offset by strength and the lack of internal structure (like strip planking) then the costs come close to balancing, but the athwartship strengthening issues crop up and the idea goes back in the round file.
I was hoping the poly would make the thing work, but only amounted to a 30% difference over unrefined epoxies. The problem is the cost of PVC pipe and the amount of filling needed to make a fair surface from less then fair building materials, plus the skinning. A 1/4" laun plywood core would cost much less, yielding 32 sq. ft. per sheet for less then 10 bucks. 32 eight foot sections of pipe will cost considerably more and not have a reasonable fair surface to work with, let alone need welding.
The weight issue is staggering once you add everything up. Conventional, heavy wooden construction is actually lighter and anything under 30 feet rivals steel in weight (seen many steel 24' day sailers lately?)
Conclusion? Build your yacht in plywood. Use a radius chine design and strip plank the chine area using this method, but everything else with more traditional techniques.
