PAR
Yacht Designer/Builder
- Joined
- Nov 12, 2003
- Posts
- 19,126
- Reaction score
- 508
- Location
- Eustis, FL
Just to test the idea of sticking epoxy to PVC I made up some samples. Several sections of 3/4" pipe were used all with WestSystem, 205 hardener and their fillers 403, 404 and 406. The pieces with unabated surfaces, thickened and unthickened attachment didn't survive the slightest of bending movement before delamination began. The abated surfaces held on a bit better, though I surmised the mechanical keying on the roughed up surfaces had as much to do with this as anything else. As I expected the colloidal silica thickened joints did the best whereas the unthickened joints the worst. I leveled the first few, flush with the tops of the pipes, but soon realized that I was tossing a bunch of filler and epoxy at this and the weight issue came to mind. This would be a very heavy laminate. The structure is 30% epoxy and reinforcement, when you make a cut through it with a chop saw. Not a good use of materials and in light of the costs of this structure limited to say the least.
You do save some money in the use of PVC, but it requires a bunch of epoxy and reinforcement, though fairing is reasonably easy with the pipe tops as a guide for the plastic applicators I used to fill the gaps.
I didn't try to fill the pipes as the structure has enough cross link built in using the pipes between sheaths. A better idea would be to chemically weld the pipes into position, strip plank style, fair then skin, but with polyvinyl or polyester. I'd think polyvinyl or polyester would have a much better chance of sucess then epoxy and would cost conciderably less.
