PVC gutter drains
Discussion in 'Materials' started by grady, Mar 25, 2021.
  1. grady
    Likes: 12, Points: 28, Legacy Rep: 70
    grady Novice
    I'm sure this has been done......so not looking for the "If's" ...but instead the best or most effective way to epoxy pvc pipe to fiberglass to provide a drain from hatch gutters??
    Thank you
    Tony G
  2. Blueknarr
    Likes: 406, Points: 83
    Blueknarr Senior Member
    60 grit
  3. grady
    grady Novice
    LOL........Thanks. Short and to the point, I guess I assumed that it was s.o.p. to abrade any surface prior to attempting to get a glue to stick to it.
    And again thank you I was looking to see if it was necessary to not only bed with thickened epoxy but may encase in a couple layers of cloth.
    just looking for the best adhesion so this can be addressed and put to bed without have to revisit it down the road due to poor technique .
    All the best
    Tony G.
  4. kapnD
    Likes: 383, Points: 83, Legacy Rep: 40
    kapnD Senior Member
    A length of rubber hose between the gutter and drain pipe takes a lot of strain off the joint.
  5. grady
    grady Novice
    Thank you KapnD, But I'm planning on running the pipe directly under the gutter and epoxying it in place then drilling through the gutter providing an outlet for the run off.
    at the end of the pipe will be a hose leading to the bilge. Having a challenge with overflow of run off water spilling over the gutter and onto my Cat powerplants.
    Thanks for your response
    TonyG.
  6. kapnD
    kapnD Senior Member
    Thanks for clarifying that, your original post was vague, readers had no idea what you were thinking.
    Photos and simple drawings are much appreciated hereabouts.
    I like your idea, my own boat has gutter drainage problems too, in the worst possible location, right over the motor.
  7. grady
    grady Novice
    Yes, ....That's very true. But the question was presented in a simple form. I find over worded or complex posts tend to bore readers so I tried to keep it simple. And just provide the important info to generate responses......My Bad!!
    So to reiterate.....looking for the best way to secure pvc pipe to existing fiberglass with having any bonding issues......
    Thanks guys
    Tony G.
