PropSim
Discussion in 'Software' started by SolomonGrundy, Sep 8, 2006.
  1. SolomonGrundy
    Likes: 9, Points: 18, Legacy Rep: 51
    SolomonGrundy I'm not crazy...
    Hi all, I'm attempting to develop a 2 bladed prop for my HPV. I have PropSim but I don't know what all the input parameters mean...what does " # of lines" and " Hub/Diameter Ratio" mean?
    I sure could use some help from someone who has used the program before...I'm just a lowley welder.
  2. SolomonGrundy
    Wow, over one hundred views and zero replies...
    Has anyone even heard of PropSim?
  3. RANCHI OTTO
    Likes: 37, Points: 0, Legacy Rep: 535
    RANCHI OTTO Naval Architect
    Hub/diameter ratio is the hub diameter of the propeller taken at his mean length divided to the propeller diameter.
    What is PropSim?
  4. SolomonGrundy
    It is a computer program for determining propshape with a given set of parameters.
  5. RANCHI OTTO
    All kind of propellers? I mean semisubmerged, supercavitating, transcavitating, conventiional, etc.....
  6. SolomonGrundy
    Only conventional props as far as I know.
  7. jehardiman
    Likes: 504, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Did you go here and read this?
    http://www.umwelteinsatz.ch/IBS/propsim.pdf
    "# of lines" is how many output lines the program gives.
    Looks like a pretty basic program based upon Pooles work, which is a good place to start. However using ideal disk theory will not produce the absolute most efficient prop, as it ignores tip and root effects.
  8. SolomonGrundy
    I wonder how much of an impact the root & tip effects will have on the prop considering the ultra low rpm & horsepower...
  9. jehardiman
    They can reduce efficency 5-15%, more if you have more than two blades.
  10. SolomonGrundy
    efficiency
    SWEET!
    That leaves 35-45 % loss in efficiency due to the rest of the system (cutlass bearing, bevel gear, sprocket hub and chain) to be within our nominal parameters...unless there's something I'm missing.
