I have a few propellor questions.
I've been reading this section quite a bit, a lot of discussions are over my head, others end in disagreement.
If I had a 50 ft displacement boat, with dual engines, dual props...
Lets say they are 24" and 24" pitch.
If the transmission is 2:1, at 2000 engine RPM, that would mean 1000 RPM shaft speed, which would net a theoretical 2000 ft per minute, which should be just over 20 mph.
What is a customary or "close" number to use for propellor slip at certain RPM's?
At 1000 RPM shaft / prop speed, would the slip be enough that the boat would still be at displacement speed, or would the pitch need to be reduced so that the ratio is lower?
( I know this boat's displacement speed would be less than 20 mph, but what I'm asking, is how much slip generally occurs with props that size.)
What I want to do, is gear this sucker so that it can cruise at a fuel effecient speed with the engines around 1000 - 1200 RPM, maybe 5-7 kns.
Generally, how much slip would a 24" x 24" prop have being spun at 500 RPM ?
Just from reading etc, it seems like the 2:1 ratio trans would be the way to go.
