Propeller Design.. Need HELP
Discussion in 'Props' started by NITHIN BABU, May 26, 2015.
  1. NITHIN BABU
    NITHIN BABU Junior Member
    Hai all,
    I'm new to propeller design, and my boss give me work to design a propeller for a self propelled barge of L=60m B=12.5m D=3.6m T=2.6m Cb=.907 .
    Need a speed of 7Knots from a engine of CAT C18 ACERT Marine Engine 715 bhp (533 bkW) .
    How do i do it.. does anybody have any excel sheet or pdf...
    please help me..
    Thanks & Regards,
    Nithin Babu
  2. daiquiri
    Is that story even possible?
  3. NITHIN BABU
    i didn't get you... what story?
  4. NITHIN BABU
    i just want to know how to calculate its pitch, radius & number of blades... if you have any pdf or text please give me
  5. TANSL
    Likes: 958, Points: 123, Legacy Rep: 300
    Forgive my impertinent question, if that pdf existed, would you be able to understand it?
  6. FAST FRED
    FAST FRED Senior Member
    I think the local engine dealer would be best source of info,
    He will know size , weight and better details of how rough the barge construction is.
  7. NITHIN BABU
    Why not, if a human being can do it then why cant i. I am a quick learner & i have confidence that i can do it..
  8. TANSL
    I did not want to offend no doubt your ability to learn. I think if you already know the theory and are able to understand an explanation of an issue is because you have studied on it and therefore already have a number of references to books, technical papers, etc. Just because you make a question like that you made me into thinking that you have not studied much about it. Hence my question.
    Cheers
  9. gonzo
    Likes: 2,366, Points: 123, Legacy Rep: 2031
    Are you actually designing the propeller or specifying it? The first means that you will decide the alloy to use, hub size, blade shape, number of blades, etc. The second, you choose from the commercially available propellers and may specify some modifications, like a slight pitch change.
  10. TANSL
    Do youn think there are "commercially available propellers" for a ship of L=60m B=12.5m D=3.6m T=2.6m Cb=.907 ? . I don't think so.
  11. gonzo
  12. TANSL
    Although I know that there are manufacturers of propellers, which also can design as the client, I'm sure that there are no "commercially available propellers", for this ship's size.
  13. Ad Hoc
    Likes: 1,995, Points: 113, Legacy Rep: 2488
    Well...this one is :eek:
  14. johneck
    Likes: 17, Points: 18, Legacy Rep: 117
    johneck Senior Member
    The power is what matters, not the length of the hull. There are many propellers that will absorb 715 HP at 7 kts. I would find the papers for the Gawn-Burrill Series of propellers or the Wageningen B-series and use that data to select optimum diameter and appropriate pitch. The other key factor is the shaft RPM, so the engine rated RPM and gear ratio.
    Whether enough thrust can be generated to push the vessel at 7 kts is another question.
  15. TANSL
    But you will agree with me that the length, breadth and depth, have some influence on the ideal propeller for the boat.
