Propeller calculation
Discussion in 'Boat Design' started by Sarfaraz Manjra, Jan 28, 2019.
  1. Sarfaraz Manjra
    Sarfaraz Manjra New Member
    Currently I am an intern working to a design an electric boat with a load of 350 KG . To select the right motor I needed calculations for the thrust and torque of prop. i have tried searching sites for formulae but couldn't understant. Please can someone tell me the exact way to approach for my problem .
  2. Pammie
    Likes: 16, Points: 18, Legacy Rep: 10
    Pammie Senior Member
  3. Sarfaraz Manjra
  4. gonzo
    Before calculating a propeller, you need to calculate the resistance (drag) of the hull at the target speed.
  5. Squidly-Diddly
    Likes: 188, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
    I gotta question:
    Say you have a 300hp motor, and need to power a 30ft typical deep V planing hull that will weigh 4 tons (or whatever is a pretty typical setup of motor and hull).
    Which would go fastest: inboard/outboard, outboard or inboard(traditional shaft)?
    And about how much diff between those motor setups?
  6. gonzo
    I would say that it would be an inboard or outboard with surface piercing propellers
  7. JSL
    JSL Senior Member
    some particulars on your boat and the speed you want to achieve would help: Otherwise, we are all guessing
