Prop hub matched to gearbox
Discussion in 'Outboards' started by DogCavalry, Sep 24, 2022.
  1. DogCavalry
    Likes: 1,802, Points: 113
    DogCavalry Senior Member
    Is this the correct relationship between prop hub and torpedo? It looks like turbulence to me.
  2. baeckmo
    Likes: 892, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    Does not seem correct, the important thing is if there is a shortcut path for the exhaust from torpedo outlet into prop hub outer surface. Could you come closer to the critical area with the camera? Also check the shape of an original Evinrude prop. There are a number of small differences in the thrust washers for the available variety of engine-prop combinations.
  3. fallguy
    Likes: 1,986, Points: 123, Legacy Rep: 10
  4. fallguy
  5. DogCavalry
    Thanks fellows. There doesn't seem to be an option to select a large diameter prop hub to go with the large diameter gear case on the HO engine, so I guess the flow discontinuity is considered acceptable in the industry.
  6. powerabout
    powerabout Senior Member
    its creates less drag, common on many large outboards when the case is a little bigger but uses existing range of props
