Prop for lightweight 15.5 ft runabout / 40 HP outboard
Discussion in 'Props' started by Peter.D, Nov 10, 2014.
  1. Peter.D
    Peter.D New Member
    Hi, what propeller would you suggest for lightweight plywood boat (about 550 lbs - boat+engine+fuel) with 40 HP Yamaha outboard engine? I'm currently using Solas - Amita 3, aluminum 3 blade prop with 11 diameter and 15 pitch and gaining speed about 30 knots. My expectations were about 35 - 40 kn...
    I was trying to use prop calculators like propcalc etc. and the resulting prop is 11/23. But this pitch seems to me out of the normal range... What prop should I try?
    My basic data are: 40 HP with max 5500 rpm, 2.0 gear ratio, 700 lbs (incl 1 man), 13 ft LWL, 35 kn required speed, C ... 170 (just guessing - between runabout and fast)
    => prop 11/23... ???
    Thanks for any suggestions.
    Likes: 1,430, Points: 123, Legacy Rep: 2031
    What RPM do you get at WOT?
  3. Peter.D
    Peter.D New Member
    Don't know yet. I'll get tachometer by the end of this week so let you know afterwards. It seems that I gain max speed on cca half open throttle and then it doesn't accelerate anymore. I'll do more testing when I get tachometer and write back. Just to let you know - this boat has 7 deg deadrise - for flat water and trim is about 1-2 deg at full speed.
  4. gonzo
    That seems like an over-propped motor. The tach will let you know.
  5. sandhammaren05
    Likes: 33, Points: 38, Legacy Rep: 138
    sandhammaren05 Senior Member
    With 2:1, 5500 RPM, 36 mph, you need 15" pitch. The required diameter is 10". Solas produces bad designs if you want speed. Also, I once bought a Solas and the pitch was 2" less than advertised! I'd buy a Turbo or Stiletto, both designed by Jim Booe in Indianapolis. The company is still run by Jim's son but was bought by Yamaha. And forget aluminum.
