Project QUIDNON nearing first build
NolensVolens
Junior Member
Joined
Dec 28, 2016
Posts
19
Reaction score
Location
Beaufort, SC
2+ years in the works, we are gearing up to build the first hull. 26 feet, 2-foot draft with kick-up boards up, goes 7.5kt under engine or sail. Private accommodations for 3 couples and 2 singles, salon that seats 12, heads with a sauna, enough deck space for a dance party, etc. This will be a kit boat, to be priced at around $50k. Please check it out and let me know what you think! And if you want to get involved in this project, please let me know.
If you have accommodation for three couples and seat twelve in the salon on only 26 feet length, that has to be really beamy. I find it hard to understand how you will also include a head and galley in it. Also, for a sailboat of this length to do 7.5 Kt, it will have to be light and have a low prismatic coefficient, which is the opposite of what you describe. The drawing shows a burdensome barge-like vessel.
Yikes, that's a typo! Sorry, 36 feet LOD, 16 feet beam. Yes, it's a barge/scow. It's a displacement hull. It's optimized to carry a bit of freight, up to 20 tons. Based on the scale model, which we outfitted with radio controls and sailed around the marina, it sails strangely well. Don't know how it will do in big seas; perhaps no worse than the average coconut. Here are all the specs.
HULL TYPE: SCOW
LOA: 37 FT • LOD: 36 FT • LWL: 35 FT • BEAM: 16 FT
STEERING: TWIN KICK-UP BOARDS & RUDDERS
RIG TYPE: CHINESE JUNK • SAIL AREA: 1000 SQ FT
DRAFT: BOARDS DOWN 7 FT, BOARDS UP 1.5 FT
DISPLACEMENT: 12 TONS • GROSS TONNAGE: 25 TONS
BALLAST: 8 TONS; WATER 5 TONS, STEEL SCRAP 3 TONS
CONSTRUCTION: FIBERGLASS OVER MARINE PLYWOOD
BUILD TYPE: MANUFACTURED KIT, RAPID DIY ASSEMBLY
ENGINE: 40 HP OUTBOARD IN INBOARD WELL
CRUISING SPEED: 6 KNOTS • MAX SPEED: 7.5 KNOTS
WATER: 1,380 GALLONS • GASOLINE: 50 GALLONS
PROPANE: 2 20-LB CYLINDERS IN VENTED LOCKER
ACCOMMODATIONS: SLEEPS 10 ADULTS, 5 WITH PRIVACY
LAYOUT: 2 AFT CABINS, VESTIBULE, GALLEY, HEAD,
SALON, 2 PILOT BERTHS, “U-BERTH” IN BOW
LOL, yes 36 feet will make a huge difference, but still quite cramped quarters
Interesting design..I wish you good luck in getting the funding for a production run...I am sure you will get plenty of feedback in here...all of it can be constructive even if it does not at once appear so...
