You might find this interesting: a cruising boat designed with a canting keel that also lifts:
MARTEN 65: Canting-Keel Cruiser by Owen Clarke http://wavetrain.net/boats-a-gear/287-marten-65-canting-keel-cruiser-by-owen-clarke
Excerpt:
But certainly the most amazing feature is the deep-draft keel, which, as mentioned, not only cants horizontally to increase righting moment, but also can be lifted vertically so the boat can access shoal-water harbors and anchorages. The operation of this versatile appendage depends on a very large hydraulic system. There is one set of hydraulic rams to shift the keel up and down inside its casing, plus another set to cant both the casing and keel together from side to side. The 24-volt hydraulic power pack that does this heavy lifting also runs a retractable bow thruster, a windlass integrated with a retractable bow-roller system, the main halyard winch, and an in-boom mainsail furling system.
Daggerboard keels and canting keels
Thank you for the information, Doug. I checked out the Marten 65 and here are my thoughts.
Italian boat builder Cariboni has built daggerboard keels and canting keels. The mechanics are similar to the keel in the Marten 65. Did Cariboni build that one too? The mechanics on our canting keel is simpler and lighter. The draft of it is only 1 meter less when compared to a daggerboard keel or typical a fixed keel, but I would still consider it significant advantage.
Due to the increased stability and the more upright position of the sailboat, our canting keel can increase the forward thrust provided by the sails as much as 60-70 %. However, because of hydrodynamic drag, the increase in speed may be only 10-25 % (when compared to a fixed-keel boat). In downwind, the speed increase may be greater, particularly if the boat can achieve a planing speed. In our opinion, the canting keel must be high performing before it can help achieve a whole new speed range and provide real benefit. Installing an underperforming canting keel is not worth it, not to a racing boat and for sure not to a cruising yacht.
The keel fin on the Marten 65 has a depth of approximately 3.6 meters and the length of the boat 21.5 meters, which makes the boat length/keel depth ratio about 6. According to our plans, the keel fin depth should be about 2.6 meters on a 12.5-meter boat, which would make the boat length/keel depth ratio about 3.3. With this ratio, our keel would be about 85 % effective than the keel on the Marten 65. In addition, the canting angle on our keel is about 50 degrees, whereas on the Marten 65 it is about 32 degrees.
A Baltic Yachts designer once told me that stability calculations are different on bigger boats, so perhaps the Marten 65 keel is effective enough after all. But in my humble opinion, an increase of 1 meter in depth and 8 degrees more canting angle would not hurt!
The Marten 65 has many of the same elements that we too are trying to achieve. In a previous post, we discussed the benefits of a deck house/saloon on a sailboat. The Marten 65 has a deck house, but according to our calculations, it would have provided many advantages had it been significantly longer, wider and higher. It would have provided an unbelievably spacious main cabin and a much more protected cockpit.
In his article, Mr. Charles Doane was quite critical of the Marten 65 stability in extreme situations: “
Her capsize screening value is also quite high for a blue water cruising boat.” Indeed, a big deck house can compensate entirely the lesser stability due to lighter keel weight in extreme heeling situations.
Perhaps a big deck house was not in fashion at the time the Marten 65 was designed (2004), but it is becoming more and more popular today.
Mr. Doane also doubts whether the rough-water behavior of the Marten is appropriate for cruising yacht:
"Though the canting keel obviously reduces heeling (and, of course, increases stability when correctly deployed), the boat's motion is still apt to be very lively when sailing at speed, particularly while going to windward in a steep chop. Take a look at that super-low comfort ratio".
In my opinion, the criticism is not called for. In an analogy, nobody says, “You should not buy a BMW with a top speed of 220 km/h, as sometimes the roads can be slick, and you can only drive it at 70 km/h.”
My point is, is it always necessary to take the sailing to the limit? Or drive the BMW at 220 km/h? If the chop is steep, can you not reduce your speed? Or sail at a shallower angle? And still arrive at your destination at the same time with the fixed-keel boats.
In addition to us wanting to bring a canting keel as a high-performance option to cruising, above all we want to create opportunities for yachtsmen to experience sailing at a whole new level. The goal is not extreme sailing, but rather, when the sun is shining, and the winds are perfect, you can sail much faster and much further and in more comfort with “a tuned-up sailboat”. Preferably in downwind. In bad weather, you can slow down or drop the sails and start the engine.
Sound like fun?
