Southern Cross
Senior Member
- Joined
- Mar 21, 2013
- Posts
- 155
- Reaction score
- Location
- So. CA
To me, the IMOCA 60's strongly resemble the Aussie 18 skiffs. I used to race the 12' version as a kid. One of many obvious and discernible differences is the ballast systems. Both are moveable, however, in the case of the IMOCA 60, ballast is in the keel and contributes to drag (unless when hiked out and your *** drags through the water). I'm sure if the designers could figure a way to hike out ballast on a 60 they would have done it by now. It seems like Speed Dream is attempting a compromise between the two.
I feel instinctually that extraneous and superfluous appendages on a boat will become a thing of the past. I cant imagine foils hitting a UFO at the speeds that are being made. But that goes more to my other post about "morphing hull forms". This isn't an argument about the benefits of foils and multihulls, though. I just wonder if it is possible ...
Say you started the design process with a ballast system, a moveable but internal ballast system and then built the hull form and designed the sail/wing plan based on the weight of the ballast system and all other components (if a boat has little to no displacement what is the total weight of the boat called?). This is probably a common approach to design. I don't know...
If you could put the canting keel ballast inside the boat, pivoting from a lever at deck level, riding on a track from center line all the way up port or starboard, below deck, wouldn't this, to some degree replace "rail meat"?
I'm just thinking that if you removed 15' of keel and so much ballast on a bulb, you could eliminate some form and frictional drag. Lateral resistance and steering could then be accomplished with chines and removable fore and aft foiling dagger boards or just stick with the same dual rudder systems already being used.
Safety. The canting keel would have to be enclosed in a carbon case probably just aft of the mast. Accommodations would be limited to the space aft of that. The keel could be locked into position to gain access forward through hatches which would be limited to repair and other similar situations.
There is a whole lot of math needed to find the optimal size boat for this configuration, the perfect balance. Clearly, you don't have to be big to be fast. A hull with less drag would need less energy to move it, no?
Lets say you start small, with say 2000 lbs of lead ballast (10 big dudes) incased in a carbon cylinder riding on rails. The cylinder would have to accommodate 5,128 cu. inches of lead? If the cylinder was 36" in diameter it would have to be around 90" long, yes? The hull form would have to accommodate 90" + at this particular point in the beam. 2000 lbs plus the weight of the hydraulic arm and the carbon case = ? ( I apologize in advance for my wretched math skills). Also, the hydraulic arm would have to telescope to accommodate the shape in the hull (greater distance from center to beam than center to floor).
So, then ... how long would the boat have to be, 20' or 40', how big of a sail plan, what sort of dagger boards and where would they be positioned to keep this boat upright and planing across oceans? Would you need any keel at all? Could you foil a boat like this?
Sorry for the sketch. Using my kids colored pencils.
Don't shoot the dreamer!!!
