Probabilities
Discussion in 'Stability' started by Antonio Alcalá, Jan 22, 2008.
  1. Antonio Alcalá
    Likes: 3, Points: 0, Legacy Rep: 45
    Antonio Alcalá Ocean Yachtmaster
    Does anybody explain me how is possible the yatch wich is in this serie of pics
    are not still sunk??? :)
      File size:
      66.4 KB
      File size:
      59.6 KB
      File size:
      48.7 KB
      File size:
      73.4 KB
      File size:
      22.2 KB
  2. westlawn5554X
    Likes: 31, Points: 0, Legacy Rep: 355
    westlawn5554X STUDENT
    It due to water tight boat contruction and the right calculation for stability... The boat is far too near land and would have problem if ran aground...
  3. CGN
    Likes: 9, Points: 18, Legacy Rep: 138
    CGN Senior Member
    They are designed for such task, they have a low cg and lot's of floatation above waterline that helps the boat to self righting itself, I have heard comments from some sailors that they are a "*****" to ride on in certain conditions because they "roll" really fast, but by no means indicates is a bad design is just they are designed for an specific task and certainly they are excellent boats
    Check this article
    http://www.proboat-digital.com/proboat/200612/
    Page 42
    cheers
  4. Guest-3-12-09-9-21
    Likes: 13, Points: 0, Legacy Rep: 146
    Guest-3-12-09-9-21 Senior Member
    Those are pictures of the 47 foot Coast Guard rescue vessels used in the United States (some other countries have also adopted this design). Check out the following site for some more good pictures:
    http://morrobayphotos.com/uscg/USCG MLB Action/
  5. Antonio Alcalá
    Yes. You're right incredible images and of course incredible 47' motorboat. Would you mind telling me who has designed this kind of yatch? Do you have any numbers of her?
  6. CGN
    CGN Senior Member
  7. Antonio Alcalá
    I´ve just seen CGN. I´m really surprised, what a incredible rolling over in under 10 seconds!!!!!!!!!!!!!!!!!! I only wanted to know about sailboats, but after that....I think everybody must have one!!
  8. SeaSpark
    Likes: 17, Points: 0, Legacy Rep: 96
    SeaSpark -
    Good fortune
    Fortunately you do not have to recognize a lifeboat when you need one.
