redreuben
redreuben
- Joined
- Jan 7, 2009
- Messages
- 2,083
- Reaction score
- 287
- Location
- South Lake Western Australia
Sure but in a kick up design the surface area can rip the rudder off the transom."Fences"
It's simple, cheap and works well
Note: This feature may not be available in some browsers.
Depends on how large you make the fence. The transom, pintles, and gudgeons should be strong enough to withstand the rudder suddenly being turned 90 degrees at speed, so if your fences are small enough that the load is smaller than that when kicking up, isn't that good enough?Sure but in a kick up design the surface area can rip the rudder off the transom.
Daniel sorry I didn't get back to you before.
Are you aware of Sidecar? It has some unique features and parts the water nicely.
He has answered some questions in this thread on Sailing Anarchy: Dear Mr. Sidecar https://forums.sailinganarchy.com/threads/dear-mr-sidecar.237849/I am, I've been studying that design some. Actually I've got some questions for that guy...
Is he on here?
The Proa File discussion forum was closed years ago, but there is still a button for registering on Sailing Anarchy.One can no longer make an account on proa file or sailing anarchy.
I haven't spent much time contemplating HP rudders Rob. The concept seems to be a mod to the steering paddle or oar of yore? The unit articulates, will knock out of the way if bumped and can be raised and lowered. The trick is of course up-sizing the paddler's arm and make it controllable.
I can think of a number of ways to do that, for cruising it certainly seems sensible. Higher speeds start getting the challenge of cavitation because of the surface piercing design.
The faster the boat, the more reinforcement of a non kick up board is required. My brother worked on SVR Lazartigue (maxi foiling tri) after it ripped a chunk out of the main hull when the fixed dagger hit something at 30 knots. The reinforcing to prevent this was huge, heavy and proved pointless. Making them kick up would seem to be a lighter, safer bet than more than half the fleet in that race suffering damage from having fixed foils.Weight wouldn't be a huge difference because of the needed mechanisms.
Love to! Much more enjoyable than displaying my pissing prowess. ;-).Perhaps we should brainstorm some refinements of these approaches.
Starting point for the discussion: I found the biggest problem with beam mounts is getting enough steering leverage. Solutions were bigger separation of the beams, bigger rudders (ie, no separate daggers), the ability to lift them for balance and the ability to steer them individually, particularly so the aft one can be locked and the front one used for steerage upwind. The other problem is support, but that can be remedied with struts and more laminate. A cool solution is to mount them on the lee side, in the beams, which is one of the experiments I mentioned above. Initially, this was to reduce the visual impact, but it moves the board drag to leeward and vastly reduces the weight and complexity of the mounting, albeit with some handling issues.the beam mount seems workable too, what are refinements?
Re rudders: In the beginning of my journey down this this arcane path I used a steering oar on my first "real" proa P52. So simple, one oar sufficed for both directions a ball and socket joint allowed some steering with just a little twist of the shaft. You could maneuver the boat around oar wise docking. But at speed ( 8-9 mph) there was this little issue of the forces involved. My favorite video of P52 passing Chuck L. on it's maiden TX200 voyage has a 1.5 second segment where I waved as we went by. The other hand had a death grip on the oar and my feet were planted firmly on the lee side of the hull. Several people at camp that evening commented on the incongruous sight of such a strange craft flying up Baffin Bay with a 48 s.f. poly tarp sail with me holding a death grip on the oar that had a significant very visible bend in the shaft.
The next year we returned with quarter rudders on the weather side of the hull and a less effective but reefable sail plan. Rudders were retractable in pivoting cassetted open ended, bungee corded and swept forward to minimise ventilation. You could steer with thumb and forefinger and I learned a lot watching the flow of water around the bidirectional (Speer 30012 sections) rudders.
Since then I have gravitated to end mounted rudders in a spring loaded vertically pivoted cassette and haven't looked back. It took a few iterations to get it somewhat right but that is part of the joy of messing around with proas. One other comment. The original oar was also intended for propulsion but fell far short of being functional, I had a lot yet to learn. I've learned a little and a AD style sculling oar is now standard equipment and also serves for emergency steering.
I miss the ultimate simplicity of that original oar and reflect on it on occasion while in my little 12' double blade EasyB canoe which is the gold standard for elegant simplicity.
Cheers,
Skip
