There is a tradeoff, dagger rudders are exposed, not ultra-shoal draft friendly and hard to build, their trunks have to be built strong an sealed behind bulkhead.
All true, but applicable to Newick rudders as well.
To quote Russ on his rudders:
"These rudders are retractable and fit in trunks like a daggerboard. Like a daggerboard they are vulnerable to damage, but unlike the daggerboards in most multihulls, the trunks are separated from the rest of the hull in both directions by watertight bulkheads to prevent flooding in the event of an impact that damages the trunk." He also says they are "complicated to build" which from someone with his boat building competence should be heeded.
Russel Brown has clocked thousands of ocean miles with this configuration (dagger rudders, daggerboard in the ama)
It may or may not be relevant, but when Russ sailed in the log infested Race to Alaska (in which he set the solo record, and was smart enough to mostly not sail at night), he chose a cat with kick up boards and rudders, not his proa with Newick rudders and daggerboard. "Ocean miles", are not very relevant as most rudder damage happens in shallow water, not offshore.
Madness proa too and they are fast, balanced, close winded boats.
The first Madness broke both it's Newick rudders when side loads were applied because they were not easy to lift and didn't kick up. The second (in NZ) also had rudder troubles. Do you have any footage or tracks of them going upwind?
My early proas (25-30 years ago) had Newick rudders. I sailed in a tidal area with lots of sandbanks and hit many of them. A benefit of a proa is you reverse everything (shunt) and sail off a grounding 'backwards'. Removing the rudders, replacing the foam, fixing broken rudders and leaky cases convinced me there was a better way. Side mounted rudders were the eventual choice after many other options were tried. The first ones were crude, the latest have a lower external profile and work well. There are no holes below the waterline, they can be partially lifted but still used in a storm or shallow water, kick up in a collision and are easily returned to their working position. They are big enough to not need a daggerboard and can be steered together or separately. Sailing loads are high, but simple and easily resisted. Impact loads are minimal so require minimal beefing up. The weight and cost savings are appreciable.
Some things to think about when you are looking at performance proa steering and leeway resistance:
1) Hit something solid (ground, whale, log, etc) at top speed. Does the daggerboard and case get damaged? If the cushion foam does it's job, how long does it take to remove the board and replace it. Is the board damaged? How quickly did the boat stop? Compare this with a similar speed impact in a car with crash zones at similar speeds and no one wearing a seatbelt.
2) Turn the rudders and run into something solid. Does the trailing edge hit the hull?
3) Can the rudders be used in shallow water sailing?
4) Can they be raised when facing the wrong way?
5) Can both rudders be used to enhance manoeuvrability?
6) Are they and the daggerboard visible so you can see weeds and plastic bags on them? How easy is it to remove these?
while we are there...
Proa question
ne is deep reaching in increasing winds & seas - & has to "change tack" - i.e. shunt...!
Wouldn't this involve coming broadside to the seas & to a standstill, until being able to take off on the other "tack"? Sound dangerous to me if wind & seas are up enough...
Definitely a problem on proas with one jib shaped sail where the luff and leech swap roles. ie the tack becomes the clew and the clew the tack. For this reason, these sails are not common and would be lowered or reefed before shunting in extreme conditions.
Almost all proas have sails which, when the sheet is released, they weathercock and align with the breeze. They can then be sheeted on gradually as the boat goes from side on to the waves to the new course.
Proa rigs with headsails or spinnakers need the old one removed/furled and the new one hoisted/unfurled, but on rigs without headsails (Harryproas), it is a simple, safe and low stress operation.
Tacking boats need to have enough sail up to power the boat into and through the wind and waves (or, more commonly these days, they start the motor). If they don't make it, they go backwards putting a lot of strain on the rudders, steering and crew. Proas only need enough sail to maintain steerage way, which is a far less stressful way to cruise and to sail out of difficult spots like the infamous lee shore in 40 knots. Harryproas have an 80% reef for this reason.
Gybing in big wind and waves is a white knuckle experience on a conventional boat. Choosing the moment, sheeting on the main, turning and releasing the main without broaching. On a Harryproa you dump the mainsail sheet and luff onto a reach. The boat stops and drifts. Trim the new foresail on and bear away onto the new course. Trim the new aft sail. Simple, safe and easy operation at any stage of which you can stop for a cuppa or to reef the sails.
It's the same principle on a sloop rigged proa, but you have to remove and replace the headsail before and after the shunt.
More on shunting at
Shunting — Harryproa https://www.harryproa.com/shunting
