fallguy
Boat Builder
- Joined
- Dec 7, 2016
- Messages
- 8,864
- Reaction score
- 2,058
- Location
- usa
has anyone quantified the difference between an epoxy bond that is wet on green vs a secondary sanded bond?
I realize this is somewhat subject to variations in substrates and epoxies and glass, but has anyone sort of averaged it out?
Like, for example, a wet on green bond after a 12 hour cure versus sanding and bonding at 18 or 24 hours.
In other words, is there a time when primary bonding ever begins to diminish to the point secondary bonding is preferred? Or, for example, if you are able to sand then secondary bonding is better?
In a more practical sense, has anyone worked in a shop where you trusted primary bonding to occur if the prior layer was no longer tacky?
My epoxy has a 72 hour bonding window. Seems a long time to trust primary bonding and not sanding, for another exmple.
