sdowney717
Senior Member
- Joined
- Nov 13, 2010
- Messages
- 1,600
- Reaction score
- 118
- Location
- Newport News VA
First thing was coat the bore and bush with dish soap
Pressed in was easy at first, then the wood split after 70% of the way.
Maybe could have warmed strut with a torch a little.
Very tight fit.
I switch to a used up cutlass and no wood to finish, and it popped with every handle pull all the way in
This is a 50 ton jack. old bushing is visible.
This old bushing is also ground smaller to a sliding fit in case I need to press out a cutlass
20 years ago I pressed in Vesconite. It held up until lines wrapped the shaft then dug into the bushing end like 2 inches got eaten, melted.
The replacement bushes are the original brass with rubber.
To get out the vesconite, used a sawzall to cut the bush, then a thin screwdriver and 2 lb sledge and cracked out the plastic in pieces.
20 years ago, used grease and It seemed to slide in easier than dish soap. It also never moved out of place. These struts have no set screws.
Very tight fit.
