Premixed Epoxy
Discussion in 'Materials' started by jorgepease, Mar 10, 2018.
  1. jorgepease
    jorgepease Senior Member
    low viscosity epoxy infusion epoxy, first I heard of it. Probably what they use on prepregs.
    http://www.hexcel.com/user_area/content_media/raw/HiFlow_HF610_DataSheet.pdf
    Seems like you could use this in a variety of ways including spraying without worry of kicking off in the gun! Imagine spraying your panels, vacuum bagging and sending them into the oven. Saves quite a bit of setup time )) ... of course you would need to have a fresh air supply breathing system and protective suit.
  2. useragentseven
    useragentseven Junior Member
    Anyone know of a facility where one could vacuum bag their hull, and oven cure it?
    What is the purpose of Vacuum bagging a lay-up anyways?
  3. Blueknarr
    Likes: 462, Points: 83
    Blueknarr Senior Member
    Vacuum bags make very good clamps over large of iregular surfaces.
    In hand layups a blotter that absorbs excess resin is placed between lamination and bag.
    In infusion, dry cloth is held to mould and resin if sucked into the very small gap between mould and bag
  4. jorgepease
    better glass to resin ratio
  5. useragentseven
    Is a home builder able to manage vacuum bagging for their hull. And if so, up to what length would be feasible?
  6. Blueknarr
    Vacuum bagging is not beyond home builders. Does take additional equipment and supplies.
    There are several threads on this forum dedicated to vac bags. Read them. Learn from other's mistakes. Do test panels. Lots of tests until you confident.
    I think the greatest advantage of vac bags to the amateur is that it forces them to plan it out more. All the ducks must be lined up to be successful. Rushing to get started and thinking "I'll figure it out when I get there"DOESN'T work with a bag
    As with all building techniques, starting with a small project before trying large ones is an excellent idea! Another way to gain experience and insite would be to volunteer on another's bag up. That way your mistakes ruin someone else's day.
  7. jorgepease
    If you are truly serious, then learn infusion. Learn on some small parts and then you will have the POWER!! )
  8. fallguy
    I would need a 34’ long oven.
    Infusion is definitely the best way to go.
    My resin losses vac/wet bagging are very high amd the process ends up with some air bubbles on the table side if a few variables are not just perfect. Mainly any bag leak. With infusion; bag leak discovery is not under a time crunch.
    I don’t mean to hijack. The product definitely has a place.
    Systems 3 makes an epoxy with a 3 hour cure time, but it requires about 90F to cure in 24 hours. Probably similar.... They told me they make it for use in Abu Dhabi.
  9. Angélique
