preliminary propeller design
Discussion in 'Projects & Proposals' started by jacckko, Nov 28, 2010.
  1. jacckko
    jacckko Junior Member
    hi guys, i'd like to make a thesis related to the preliminary propeller design, so finding the optimum circulation.. I found in internet a thesis wich use a matlab tool related to the induction factors.. could I use it for my thesis??
    Any ideas of how continue the thesis??
    thanks
  2. daiquiri
    If you don't show us what you've found, it will be difficult to answer... ;)
  3. jacckko
  4. jacckko
    anyone can help me??
  5. daiquiri
    Well, both works you have linked describe in a pretty detailed manner the mathematical formulation used. The first work is purely teoretical, no comparisons with experimental data are shown - while the second one shows some validation results.
    I am not familiar with the OpenProp, don't know if it uses a lifting-line or a vortex-panel formulation. Don't have time now to investigate into the software documentation.
    But, generally speaking, all lifting-line prop design software share some common accuracy issues, which become more pronounced with increased blade loading - like under-predicting Kt and Kq at low J. This is due to increased inluence of transverse flow components (which are neglected in the lifting-line formulation), but also due to methods used for the evaluation of induced velocity components, which are not very reliable at high disc loadings. A blade wake made of constant-diameter helical vortices is a mathematical hack valid for a lightly loaded propeller disc, but giving an increasing error as the loading becomes higher and the wake contracts.
    Furthermore, there is a problem of the spanwise velocity of separated flows in the root (hub) region, which is induced by the centrifugal force. It is not accounted for in the 2D airfoil lift-drag curves on which lifting-line mathematical formulation relies, and significantly modifies the post-stall characteristics of the affected area of the blade. It is a well-known phenomena to aeronautical engineers which have to deal with high-rpm props and rotors, though I don't know how important it is for ship props which are revving at lower speeds (and hence centrifugal forces acting on separated boundary layers are much lower).
    Vortex-panel methods have the capability of anlysis of more complex 3D-shaped propellers, like highly skewed or raked props. They can give a more detailed info about points of possible onset of cavitation. But they also tend to underpredict the coefficients at low J's, mainly due to inability to model the leading-edge flow separation at high blade loadings.
    That said, if your design point is in a low or moderate-low disc loading zone, you can use the above tools for a preliminary prop design and optimization. Because of the aforementioned hydrodynamical issues, don't be too confident in the results at J < 0.4 (or even 0.5) without further validation. And also don't rely the results if the pressure distribution indicate the possibility of cavitating areas of the blade.
    Cheers!
