More than you wanted to know on conic delelopment with Autcad.
daiquiri
I think we are talking at cross purposes here. I have been describing the behaviour of developable hull plates in chine hull forms. I don't see the relevancy of tangency in that application, unless I have missed something?
I do not use Autocad to create surfaces at all - it is not really a surface modeller, although I do use some of its mesh surface applications in some engineering applications not connected with my nautical interests.
The Autocad process that I use is just to test whether two curves (the centreline profile and the chine in this case) can be related conically or cylindrically.
All the conic projection lines (which will be the ruling lines if the surface is developable, but at the early are just theoretical conic projection lines) are manually drawn form an arbitrary source which is forward of the full and to one side. Because we are dealing with two views, there are two graphic representations of the same source (on the plan and the profile drawings), obviously both will lie in the same y,z plane at the same x value. The source in the profile view can be adjusted for z, the source in the plan view can be adjusted for y. In autocad, this can be done by stretching the source point and the projection lines, using an “open” selection box, with "ortho" set to "on".
So, how so I actually check the plate for being developable?
With the hull lines set up as depicted in my drawing, I draw a series of vertical gridlines, which define sections through the hull. These are normally at the same location as the design stations in my hull, although I may add some others forward if there are not enough.
I then create an arbitrary focus point / cone apex / source point forward and below the stem on the elevation drawing. I draw another source point on the plan drawing at the same x location as the other but on the other side of the plan centreline, so that the projection lines cross the centreline.
Then connect each source point to each intersection of the vertical gridlines and the chine line, in both plan and elevation.
I use different colours on a rotating basis is to avoid confusion while drawing. You should wind up with a drawing similar to the one I have posted.
Where each projection line crosses the centreline profile on the plan drawing, a line is drawn up to the equivalent projection line on the elevation drawing. Where this connecting line meets the projection line on the elevation drawing is where the centreline profile must be located. This is done for every projection line and the points are connected with a polyline. The polyline may be “curve fitted” but not “splined”, as in autocad, control points for splined lines do not lie on the polyline.
If your new polyline sits close to your keel centreline on the elevation drawing, then the hull plate is developable. If it does not, then you have some options:
1. Move the apexes of the conical lines ( either both forward or back, together) or sideways or vertically, independently. Don’t forget that they must both be at the same x location.
2. Move the chine line either in/out or up/down and start again.
3. Accept that the plate is not developable and plate the hull in strips.
Once you have got your head around this, think about the fact that that the plate under consideration does not have to have a single conical focus, it can have as many as you can cope with, as the governing cone can be of changing radius. What this means is that the new cone focus has to share a ruling line with the previous cone focus to ensure that the cones are congruent. This is simpler than it may sound but it can make for a very messy drawing, so I have not shown it.
It is quite possible to develop a very shapely hull with only one focal point.
As you get toward the stern, you can be less fussy, because you can take liberties with the plates as they approach the transom, and you can induce some curve of your own, which can make the panels stiffer.
In my experience, plywood is stiffer than steel plate, which is stiffer than alloy. This makes plywood is very close to a “perfect” plate material, in that it will not readily conform to any noticeable degree of compound curvature, unlike alloy, which can be coaxed into a surprising amount of compound.
Cheers
Al
