Homefront5
New Member
- Joined
- Aug 16, 2021
- Posts
- Reaction score
- Location
- Pennsylvania
I intend to build an outboard powered wooden boat from Harry Sucher's book, Simplified Boat Building: The Flat Bottom Boat.
The bottom is about 4' wide at the stern and has about 6" of rocker. I know this boat will not exceed hull speed and is not meant for rough water. I will be using it on lakes, bays and rivers, with up to 4 adult passengers. I'm going to install a center console with a modest windscreen and a small top, which could be cedar or canvas. It will also get a dodger and maybe a small staysail for use when anchored or fishing.
I want enough power to deal with winds and tides, without overkill. This design is for a transom mounted outboard and I'm considering a 9.9 high thrust. Would a little more HP be prudent or would the 9.9 HT be plenty for that hull?
