FranklinRatliff
Previous Member
- Joined
- Feb 25, 2006
- Posts
- Reaction score
- 13
- Location
- Florida
1998 design study by aeronautical engineer Darrol Stinton
Note: This feature may not be available in some browsers.
I do not think they have reached supersonic speeds on a land based vehicle yet. I once met Gary Gabelich who held the land speed record once, he was later killed in another speed attempt on a motor cycle.
I do not even see how it could possibly done on water unless you are flying in ground effects over the water. than it is actually a water launched aircraft, not a boat. How would a few foils in water behave at 700 plus mph? where would you find a glass smooth lake large enough? The foils would disintegrate long before you reach mach one, or you would lose control and the whole ship would be destroyed.
And to what purpose, to say you built the fastest boat? Not much of a boat even if it was possible. Sounds really foolish.
Yes, The wiki page shows the current water record at 317mph, which isn't even half way to supersonic and the fatality rate has been 85%.
http://en.wikipedia.org/wiki/Water_speed_record
The sketches on the first post are not remotely realistic. The power requirement is off by a mile and the vessel would be much larger. The Thrust SSC needed 50,000 lb of thrust (110,000 Hp) to go supersonic on land. Water will require even more power.
Many of the members here are gearheads. Sometimes we do things "just because we can". When we build something, whether practical or not, we test our preliminary ideas by assesing three things; cost, risk, reward.
A potentially supersonic boat/plane could probably be built. I am at a loss to reconcile the first two tests with the latter one. Put them on a scale, one and two on the left and three on the right, and they will not balance.
I reckon that Daiquiris comment was pretty near spot on.
The people who do build and run water speed boats and land speed record cars weigh things differently in their calculus.
