positive floatation?
Discussion in 'Boat Design' started by stonedpirate, Apr 9, 2010.
  1. stonedpirate
    Likes: 3, Points: 0, Legacy Rep: 23
    stonedpirate Senior Member
    Hello,
    If i attached 2 torpedo shaped objects filled with foam to either side of my deck, similar to amas on proas but closer in, is that a standard way to keep a boat afloat if completely swamped?
    I just dont have space on board for foam.
    Any other ways to create positive bouyancy?
    Thanks
  2. GTO
    Likes: 9, Points: 18, Legacy Rep: 101
    GTO Senior Member
    Your best bet is to just copy Yankee Girl and Gerry's method of provisioning, ie, load up on foods that float.
    You could build with foam and glass. Then add water-tight lockers and a mast which floats. The inherent insulative properties of the foam might come in handy. The inevitable higher freeboard will aid in keeping the water out if you build in some serious water-tight hatches. You will be building something somewhat like a catboat anyway (L/B~=2). I wouldn't worry about adding a few extra inches for foam.
    With just 10 feet to work with, there are only so many permutations that result in anything remotely approaching a decent boat that can actually sail AND provide any type of life supporting habitation
    Since you're shooting for Serge's record, I suggest going to 11 feet in length. At this size, even an extra foot will help alot.
  3. alan white
    alan white Senior Member
    The boat should be enclosed so that water has a hard time getting in. The problem with your situation is that you have to comprimise and decide whether you want extra food, water, and spares, or flotation. It would be sad if you sacrificed water for flotation and then died of thirst.
    Ten feet is short. You could construct the hull with a core of foam, but again, less interior space or too wide.
    The boat is certainly easy to make unsinkable with enough foam for a light condition---- but you'ld have reached a point where you had given up on continuing and had called for help.
  4. stonedpirate
    So thats a negative on torpedos?
    I have considered using a skirt for the hatch so when it is open and i am standing, no water can splash in the same as sea kayaks.
    Just trying to come up with a plan incase of comple swamping.
    Positive floatation with give me a raft to survive a storm and i can bail it out in calm weather.
    Cant make it self rescuing without a lower cockpit on back.
    Floation is my only option.
  5. stonedpirate
  6. masalai
    masalai masalai
    Wear a PF1 at all times... attached "pods" - - - 'will break free when you least expect, - and most depend on them to stay'... Fools law #1
  7. stonedpirate
    you high?
  8. masalai
    masalai masalai
    and dry, not on beer or wine yet...
  9. dskira
    dskira Previous Member
    What you need is: a hammer, nails, pieces of wood, a piece of bamboo, a king size bed sheet, and put the ****** together and go sailing.
    Boston has allready the lawyers lined up for the part of the will, but he does not know you are in this thread, so I have an advantage on him.
    Go my friend, fast and........goodby.
    Where did you put the safe?
    Daniel
  10. stonedpirate
    Funny the first 10 times....
    Actually, wasnt that funny the first time.
  11. BertKu
    Likes: 45, Points: 58, Legacy Rep: 223
    BertKu Senior Member
    StonedPirate, have you considered a couple of canisters and airbags. Either in or at the outside of your boat.
    Bert
  12. bhnautika
    Likes: 55, Points: 38, Legacy Rep: 571
    bhnautika Senior Member
    SP you could line the inside with 100mm of polystyrene or similar, you would get good insulation and buoyancy. You could also add a foam/fiberglass rubbing strake which would also add some more buoyancy.
  13. dskira
    Agreed, sorry about that.
    But honnestly, you have to start building.
    It is better to built something, it liberate from the unanswered question, because all the answers come as you built.
    And if you make a bad boat so what, you learn something and start again.
    On that size, experiment in real size is the way to go.
    Think simple: a cork, with a ballast and a little sail, can float for ever and no storm ever will sink it.
    Now the guy inside the cork, oh boy, he will be all black and blue and piuking all over. But so what.
    As for the coutry you will visit? don't bother, they are not bad people.
    If they don't like you, you will have free room and board :D
    Daniel
  14. stonedpirate
    you certainly have a flair for sarcasm..
  15. GTO
    GTO Senior Member
    I don't believe Daniel was being sarcastic.
    You admit you have no experience either building a boat or sailing a small boat.
    No one here can really design a small boat that is certain to make *you* happy.
    To design a 10 foot boat that provides for your mental and physical needs, requires the answers to way to many questions. Given that you haven't sailed, *you* don't even know the answers.
    Both Gerry and Serge were boat people that had built and sailed on boats before. They *knew* what they wanted and needed. Even with that knowledge, they still had a tough time of it.
    Build your first design as a cheap, throwaway prototype. Exterior grade construction plywood, use Titebond 2 and glue up some 2x4 or equivalent and shape as necessary for a mast. Build in your lockers, sleep area, and so forth. Use sand or rocks or scrap metal for ballast and go sail/live on the thing. No doubt you will figure out what works and what doesn't.
    At the very least, do a mock up of the "living" area of the boat in cardboard, then live in it for a week! Even that will help point out ergonomic flaws in your design.
    If you have the spare time and money to spend 500, or more, days floating around the earth, AND you really want to succeed in your adventure, I can't see where adding 6 - 9 months more for at least a little proper research and development is going to hurt you much.
    Or to put it another way. How would you feel if you put all your money into the boat and provisions but then had to abandon it within your first 30 - 40 days out? Or made it to a country or two and then realized the boat just wasn't going to work so you have to ship it all home?
    Slow down a bit and get it as close to right as you can, because there are lot of other things that can go wrong that you have no control over and you don't want to be wearing yourself out with the stuff you should have squared away before leaving.
