Pop rivets on carbon spars?
Discussion in 'Fiberglass and Composite Boat Building' started by GrahamR, Apr 23, 2018.
  1. GrahamR
    GrahamR Junior Member
    Hello,
    Can any anyone advise me on the best type of pop rivets for attaching stainless steel fittings to a carbon mast section please? I have read somewhere that "split rivets" are available which spread wider internally to reduce localised loading to the laminate. The other problem as I understand is that common rivet materials such as monel metal are too far removed from carbon on the galvanic series, hence likely to suffer corrosion.
  2. redreuben
    redreuben redreuben
    Titanium is the closest I believe.
