Polyurea
Discussion in 'Materials' started by Lisbeth, Sep 16, 2025.
  1. Lisbeth
    Lisbeth New Member
    Hello, does anybody know something about Polyurea coating on the outside of a steel ship hull?
    For example:
    How many years does a polyurea coating last? Any live examples? (I was hoping 20 years?).
    Costs?
    How to repair it?
    Is is a good idea at all?
    Does ultrasound still work - does it measure through the coating?
    How thick is the coating and is it only one layer
    Does it work like antifowling? or how to maintain it / clean it?
    Is it still necessary with anoten?
    Does it give stability to the hull?
    I would be very happy to hear about your knowledge and experiences!
  2. montero
    Likes: 82, Points: 28
    montero Senior Member
    Hi Lisbeth!
    I don't think you find many answers . Those polymers are incredible and I plan to test polyurea coating at the hull . I saw really wired test of polyurea : one guy throwing hand grenades on car covered by polyurea.Results was surprizing.
    https://www.ripublication.com/ijaer10/ijaerv10n1_90.pdf
  3. Lisbeth
    Lisbeth New Member
    Thanks for your reply. Yes, we really want to do it as well because it sounds as a very durable coating for the hull, just mainly the part under water. But I wonder that noone has experience? Is it maybe too new?
  4. montero
    Do you have specific product in mind ? It will be only layer of protection ?
    I think surface preparation and application condition will be most critical.
  5. ondarvr
    Likes: 699, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    It's not new, it's just that some of these products, as good as they are, don't always catch on easily in certain markets. While it is used in some composite applications, over steel may be a bit tricky due to required application methods and processes. What can easily be done on a small surface may not scale up easily to do a large steel hull and provide a reliable barrier.
  6. gonzo
    It seems to be used over concrete fairly often. Is it too brittle for steel? I wonder if the deflection of the hull would make the paint delaminate.
  7. Lisbeth
    Lisbeth New Member
    Yes - I wonder too. If it is on a 20 meter steel hull I would not like to see it delaminate!
  8. montero
    You can always use some kind of primer.
  9. montero
  10. montero
  11. gonzo
    Primer won't help if the coating is too brittle. Further, urea is supposed to have better adhesion than any primer.
  12. montero
    Yes, a primer is a completely different idea.Polyurea it's strechy and hard . First link at this thread is locked now but those India guys demonstrate flexibility.
    From what they write, these are mixtures designed for steel structures. They specify roughness grades and application ranges. The costs aren't low, but this stuff is amazing.
  13. gonzo
    It can't be both.
  14. montero
    It is. I have more ideas how to use it .Some experiments are needed and knowledge how to omit expensive equipment.
    Hardness Shore A30-D80.
  15. gonzo
    You keep on making conflicting claims. Shore A30 is very different than D80. In fact, so different that are in different scales. Do you simply make up data? There is no need for experiments, the data is available from the manufacturer.
    1. Ace Dragon
