Having researched (with the help of a lot of you on here) and discarded a lot of ideas like RIB's, Stabicraft-style vessels etc. I am pretty much set on a 12 x 5.5 metre Poleson Marine hull design to be built from aluminium and then used as a diving vessel to support maritime archaeology here in the Red Sea in Egypt.
The Poleson Marine designs give us tons of deck space which is critical for diving vessels. Part of the reason for this is that the design puts the cabin so far forward which leaves a massive aft deck.
12 metres is the maximum length as anything bigger than that becomes far more complicated to get licenced here locally.
The minimum crewing will be two persons (200 kg), the maximum loading will be 1900 kg (2 crew + 10 divers and their dive gear).
The ideal cruising speed is 24 knots, no particular figure has been determined for needed maximum speed.
Because the local area has seen more than its far share of shipwrecks due to the treacherous reefs including one of the world's worst maritime tragedies we will be making the vessel available to local authorities whenever it is not being used for diving - e.g. night times.
Local sea conditions vary from bathtub smooth to very stacked up and confused 6 foot waves and swells.
Range will need to be 600 nautical miles.
Main questions left now are -
- displacement or planing hull?
- propulsion - the local limit for outboards is 300 hp per engine, no limit for inboards
- waterjets would be nice but are sounding like they might be very expensive
- dynamic positioning would be nice but again the equipment needed for that is sounding very expensive
