Pocket tunnel bateau
Discussion in 'Fiberglass and Composite Boat Building' started by Cajunpockettunnel, Aug 23, 2020.
  1. Cajunpockettunnel
    Likes: 136, Points: 43
    Cajunpockettunnel Senior Member
    hoytedow likes this.
  2. hoytedow
    You might want to inspect the needle. It might have some corrosion.
  3. Cajunpockettunnel
    The carbs were out of sync. I got it running again. I think my throttle cable is worn. It doesn't return enough to bring it back down to a decent idle.
  4. Cajunpockettunnel
    A bad fuel hose will create all kinds of problems. All this time I thought I was having electronic problems. Now this girl runs like a scalded ape.
    DogCavalry, BlueBell and hoytedow like this.
  5. Cajunpockettunnel
    hoytedow and BlueBell like this.
  6. BlueBell
    Likes: 976, Points: 113
    A room with a view.
    Cajunpockettunnel likes this.
  7. Cajunpockettunnel
    Look at the underside. She turned out to be a modified sled like what DogCavalry is building. Not by design, but by accident.
    DogCavalry and BlueBell like this.
  8. Cajunpockettunnel
    There's one seat. Still have some bracing and varnishing to do but it works.
  9. Cajunpockettunnel
    That is the lower unit drain plugs. There's not a piece of shaved metal on them. This motor just gets better and better. The gear case is at 100%.
    DogCavalry and hoytedow like this.
  10. Cajunpockettunnel
  11. DogCavalry
    Likes: 1,576, Points: 113
    DogCavalry Senior Member
    That is a sweet ride René!
  12. Cajunpockettunnel
    It needs some more paint and varnish, but, other than that it's good!
    Thanks!
  13. hoytedow
    It looks real good. A wrap for the bimini top is good insurance when trailering.
  14. Cajunpockettunnel
    I have one. The bimini never stays down unless it's at the house. I pull it with the bimini up.
  15. hoytedow
    I always tow with it down and secured. I've seen bad things happen to open biminis on the highway.
    BlueBell likes this.
