fallguy
Boat Builder
- Joined
- Dec 7, 2016
- Posts
- 9,037
- Reaction score
- 2,118
- Location
- usa
Thanks @Rumars . Every conversation with you is educational.
he is great; an encyclopaedia of boat knowledge
Are you going to be subject to survey John? Private message me if u like.
So, in order to build a plywood tank; if you think you can get away with it, there is no way to seam the inside at the top without a hole in the tank that is then only tabbed on the outside. The only way I can imagine in my Covid fog to build a tank would be to glass over a bladder a solid glass tank. But this is infinitely more difficult than sending out for one.
I suppose, let's say you cut a 6" hole in a plywood top and that allows you access for inside tabbing. Then you could lay plastic in the bottom of the tank and then laminate a round piece of glass onto the cutout that was say 2" around and then pull the plastic and thixo bond the fiberglass to the tank top. But man, lotsa work. Then the fittings gotta be right, too.
I happen to have an aluminum belly tank here. How big is the hole midship dimensionally?
