Plywood/foam equivalency?
Discussion in 'Materials' started by SpiritWolf15x, Jan 11, 2018.
  1. rwatson
    rwatson Senior Member
    That's a pretty good summary of the task, but the hard news is , it ain't going to be easy.
    Multihulls with potentially very large point and slamming loads would be a major rewrite of the plans. You won't be able to do an easy substitution.
    If you had a Naval Architect who was interested in the project ( say Mike Waters, who has a similar trimaran on his design list) W17 Study Profile http://smalltridesign.com/W17/study-profile.html
    .. and has owned Buc 24's, he might be able to do you a competitive quote for foam.
    This project is too big for reliable "guesstimates"
  2. fallguy
    fallguy Senior Member
    You need to find a good naval architect to help you or make some guesses based on intended use since the designer is no longer with us. I would prefer the former.
  3. rberrey
    Likes: 19, Points: 18, Legacy Rep: 112
    rberrey Senior Member
    Ed Horstman,s book " Foam Fiberglass Sandwich Construction " has Wood to Foam conversion on pg. 9.3 . It should be a good rule of thumb , but keep in mind it might be better to go up 1/8 th inch as he listed 1/2 on material list for the 31 , but 5/8 on actual . Rick
    fallguy likes this.
  4. PAR
    These conversion lists are fine for a replacement panel or odd job, maybe some furniture upgrades, but not the whole plan set. It might be best to find a similar design in the method you'd prefer.
  5. SpiritWolf15x
    Likes: 1, Points: 18, Legacy Rep: 15
    SpiritWolf15x Senior Member
    All this wouldn't be a problem if wood was actually a suitable building material. Lol.
  6. rwatson
    There are more wooden boats in the world than any other material.
    Wood is fine, if you know how to build and maintain it.
  7. fallguy
    See my private message for some ideas. This boat was done in foam by someone before and I gave you a possible lead on it.
  8. rberrey
    I would have to compare the foam and wood plans for the bulkheads to tell if Ed followed his Hull Conversion formulas . He advises to go with wood for the bulkhead,s but has plans for both . I would think converting things like hull and stringers would be fairly safe .
  9. freddyj
    Likes: 18, Points: 18, Legacy Rep: 37
    freddyj Senior Member
    Having built a wood Buc, if I were to do it again. I'd use foam instead of plywood. Though I would still wants the frames to be wood.
  10. redreuben
    redreuben redreuben
  11. Steve W
    Likes: 63, Points: 48, Legacy Rep: 608
    Steve W Senior Member
    Don't forget that if your foam/glass skin thickness ends up being thicker which it probably will, you need to allow for this in your station frames as all calculations are to the outside of the skin.
  12. TANSL
    If I have not misunderstood, I think that statement is not correct. A well-calculated compound should be made by calculating the efforts in all its thickness, not only on the outside. It is mandatory to calculate that each of the layers that compose it is subject to admissible stresses.
  13. rwatson
    TANSL = he means all STATION DIMENSIONS, not stress calculations !
  14. TANSL
    Be quiet, Rwatson, quiet, that is going to give you a heart attack. As far as I know "all calculations" is not the same as "all STATION DIMENSIONS".
    Wow, what aggressiveness! Breathe deeply a couple of times, before writing, please.
    The measurements of the frames are usually taken inside the skin.
  15. Steve W
    Ok, perhaps I shouldn't have said all, what I meant was hydrostatic calculations, so, as rwatson said, if you end up with a thicker skin you would reduce the station dimensions of the building jig by a like amount if you want to retain the designed displacement. Of course its not quite that simple as if you are trying to substitute a foam/glass panel for a ply one you will not be just comparing to a ft2 of 1/4" ply but rather a panel that includes the stringers. I don't know the scantlings of the Buc 24 but my guess is it has bulkheads gunwhales, chines and then fairly small stringers on maybe 6" centers, whose job it is to break up the panel to give adequate stiffness with that skin thickness. Without the stringers the ply would be much thicker, so, you need to come up with a foam/glass substitute that is equal to the stiffness and weight of 1/4" ply including the stringers, not just the plywood alone. Most of that stiffness is going to come from core thickness more than the laminate so you will likely end up with a 10 or 12mm core so you will need to reduce the stations to compensate. I remember reading an article many years ago by Lock where he stated that (at that time) the only boats of his designs that came in at designed displacement were the wood ones, the foam ones were all heavier. That was of course before we were infusing panels on a table with better control of weight
    Yes, the frames are of course to the inside of the skin, the hydrostatic calculations to the outside, which is why if the skin is thicker you need to reduce the frames by the difference.
