Plywood and Such, Complications, etc.
Discussion in 'Wooden Boat Building and Restoration' started by mgriffin, Sep 27, 2009.
  1. mgriffin
    mgriffin Previous Member
    You have made a very good point PAR, and ever since I decided to try and build a boat, I have searched for a certain type of boat. It meets all of my requirements which are these:
    1. It has to have a shallow draft
    2. It has to have a high load capacity (at least 1000 lbs maximum capacity)
    3. It has to have some freeboard so it can survive small waves
    4. It has to have some rocker (at least 4 inches, which on the TIMS design is in the front half only)
    5. It has to be slightly narrow, (4 feet wide)
    It meets all of my requirements, and it will only be 16 feet long, so what can go wrong? I might as well tape the seams, I mean ow hard could that be?
  2. mgriffin
    I understand what you are saying, but I am going to build only TWO sections, which is around 6 sheets of ply if I build a cabin on it, and it will only be 16 feet long if I build TWO sections like I said above. Front half and back half. It's that simple.
  3. Wayne Grabow
    Likes: 17, Points: 18, Legacy Rep: 297
    Wayne Grabow Senior Member
    This was my first build which I used on the Platte River.
  4. mgriffin
    How old were you when you did your first build Wayne?
    I hope to be fourteen when I build my first boat. I turn fourteen this month.
  5. Wayne Grabow
    Michael, I was 28 when I built that boat. You are definitely starting young. Be careful about boatbuilding; it can be addictive. I am now building my seventh boat.
    That 16' boat was built of 1/4" fir AB plywood over a frame, bonded with resorcinal glue, and with fiberglass tape on the seams. It was light enough to car-top; and well-suited to the wide, shallow Platte River.
    Good luck with your plans.
  6. mgriffin
  7. hoytedow
    Hi, mgriffin,
    How old is the engine?
    How many hours has it been run?
    Was it maintained?
    Can it be fitted with a backfire flame arrester?
    Ask these questions. Price is not bad. You will need the flame arrester for safety, especially if the hull is enclosed where gas fumes can accumulate.
  8. troy2000
    troy2000 Senior Member
    You know, I have a bigger version of that engine buried in a shed at the back of my property, on an old power reel mower. Unless some thieving little scumbag has stolen it, of course. They've been vacuuming up anything they find in the neighborhood lately, and selling it to a new scrap dealer who opened up down the road.
    I haven't looked at it for a while, but I think it's about a 5-hp motor. Would it be feasible to do some sort of inboard power on a sharpie with it?
  9. hoytedow
    I have seen a similar engine run a paddle wheel. Why not a prop shaft?
  10. troy2000
    Maybe I could do a paddlewheel Sharpie.:D
    Or not.....
  11. hoytedow
    You will grab attention, and a lot of laughter, most of it good-natured.
  12. mgriffin
    I wouldn't laugh, I would be in my boat blowing past your boat, laughing my *** off as I pass you multiple times! ;)
    (Good natured humor eh? :D)
    Hey look what I found! talk about THUNK...THUNK..THUNK..THUNKTHUNK at 1:34!
    http://www.youtube.com/watch?v=jn5PA8UYCfU&feature=related
    wish you had one now? well it would be good for stationary, IDK about an inboard...
  13. hoytedow
    Slight contradiction, but I get your drift.:cool:
  14. mgriffin
    yeah, I wouldn't want a paddle wheeler unless I had a steam engine and a perfectly flat bottomed hull! The advantage of paddle wheelers is they can go where no other boat can go. Well, that and they're pretty awesome looking.
    BTW, my hull will not be enclosed.
    If I remembered my evil-bay account, I would ask those questions. I'll have to ask my mom if she remembers my account username and passcode. I guess it's a good thing that the guy selling it has 100% positive feedback at least!
  15. rasorinc
    rasorinc Senior Member
    A simple light weight layer of fiberglass assures you the bottom and sides are waterproof. I would never omit this simple process on a boat such as you posted. An all mahogony boat, yes but not yours. Why risk the beginning of an instant rotting process after you worked so hard to make it.
    1. Brian Fredrik
    2. CaptChap
    3. NorthLakeFisher
    4. AwJees
    5. sdowney717
    6. Sunburned One
    7. sdowney717
    8. Travis Grauel
    9. Paul D
    10. Floatything
