ply/glass vs foam/glass for a cockpit floor
Discussion in 'Boatbuilding' started by bigbear69, May 24, 2015.
  1. bigbear69
    bigbear69 Junior Member
    Hi,
    Am in the process of renovating an 8M trailer sailer and was thinking about trying to save weight where possible.
    wondering what material I should use for the cockpit floor?
    options are:
    9mm ply sealed on the bottom glass on top - strong but heavy?
    6mm ply glass on bottom and top - maybe not strong enough??
    12mm foam core glass top and bottom - strong enough?
    would there be any significant weight saving in going with foam?
    would foam be impact resistant enough for cockpit floor?
    would I have to add a couple layers of glass on top?
    any advice much appreciated
    cheers
  2. Mr Efficiency
    I have used 15mm foam in a powerboat, and impact resistance is only a problem if you keep dropping anvils on it. Probably had about 3mm or so of glass on top, half or a little more underneath. Made it in one piece about 20 feet long, up to 7 feet wide, then glassed it in. That may not suit your application.
