24' cold-mould moulded plywood boat with many years. Needs general TLC but generally in good condition.
For aesthetic reasons and for long term rot prevention I was wanting to saturate with epoxy the ply under the bulkhead and then completely fill the gap between the bottom of the bulkhead, frame, and hull with timber strips and thickened epoxy. The ply is the inside part of the hull and is 9mm thick. Attached are a couple of photos showing the area.
The bulkhead is attached to the frame which itself is attached to fully bonded stringers. The frame also has a gap between the hull and their base. The shroud chain plates are attached to the bulkhead.
In the bow area there is a bulkhead forming a watertight crash box when closed. There are no gaps between the hull, frame, and the bulkhead here.
I've always understood that the more bonding of different parts of a boat to the hull the better as it will make it more stiff and stronger. It seems however what I want to do is not necessarily a good idea. There are discussions on some forums advising that this creates a hard spot.
There are probably pros and cons with what I want to do but being a non-professional I want to make sure I'm not making a major mistake (as opposed to just a con)?
Thank you
Thank you
