Plug-in solar panel option
Discussion in 'OnBoard Electronics & Controls' started by Stuft, Nov 30, 2008.
  1. CDK
    CDK retired engineer
    If you succeed in overcharging your battery with the panel you've described, you can probably walk on water too.
    I have a 16 Wp panel and 240 Ah of batteries, live in the sunniest part of Europe, yet the charge is only just sufficient to compensate for self-discharge, the bilge pump and 8 mA for the alarm system.
    In the past, I had a bilge pump with only a float switch: the panel could not cope with the power consumption. Pump and switch kept each other busy for hours because the back-flow of the water still in the hose was enough to switch the pump back on again.
    So I added an rc-delay and a transistor that keeps the pump going for approx. 10 seconds after the float breaks the circuit.
  2. Ratch
    Ratch Junior Member
    Hi CDK
    We started discussing overcharging the battery when Stuft decided to get a new panel.
    As things stand now:
    Battery size - unknown
    Panel size - unknown (was an old 5w)
    Pump size - 1.9amp@12v (googled make)
    Pump run time - guessing between 5-10min per day.
    Mooring location - Sydney or around there
  3. CDK
    Thanks Ratch, I missed that. My 1200 m. telephone cable, hanging on poles under the power cable makes the internet very slow sometimes.
    Stuft mentioned 350 Amps for the battery: I guess he meant cranking current, so the capacity will be approx. 50 Ah.
  1. Squidly-Diddly
  2. yipster
  3. sdowney717
  4. brian eiland
  5. ProBoat
  6. Vulkyn
  7. Jonny3777
  8. Vronsky
  9. BertKu
  10. Vulkyn
