Hi
I need some advice on building two cheap amas from a plug that is almost finished. I've built the plug by reshaping and lengthening a Tornado cat hull to 9m (+- 29ft). One third of the plugs surface is Tornado hull and the other two thirds are plaster of paris over various structures including chicken wire and wood. The plug still needs around two weeks sanding and filling to get it to a respectable fairness and finish.
I need advice on the following:
1. What is the cheapest method to get two amas from this plug. I don't need hi-tec or low weight, the main center hull will be a Soling mono hull without it's keel. The Soling is constructed out of single skin GRP and weighs about 430KG. In other words this Trimaran will not be a light weight racer but more of a cruiser camper day sailer.
2. I cannot afford to make a female mold and would like to turn this plug into a male mold that will withstand two hulls, afterwards the plug will be disassembled and the Tornado hull currently in bedded in the plug will be reunited with it's partner and hopefully sail again.
I have no idea on how to strengthen the current plaster and Tornado plug to make it capable of giving me two hulls. My question is: How should I go about finishing the plug/male mold?
3. If my thinking is correct the cheapest way will be single skin Polyester and glass for the hulls with lots of sanding and fairing before painting.
I have no clue on what the layup should be if this should be the way to go.
Please help, I cannot afford costly mistakes. This project is really running on a shoestring budget.
Many thanks
Many thanks
