Obviously ive got the transom to do, im expwcting to have to do the lot, but will cut away in sections to see if i hit good wood. Then il rebuild it to full height and maybe even extend the stringer knees when i redo those. The boat is painted and if i put a jackplate on the stern for an outboard then most of the bad will be hidden if i cant get a great finish.
I have the next week off work, have removed stringera and ground to clean glass on all but the last section from the bulkhead you can see in the photo looking aft. I will replace that and join to the new stringers once the transom is done as i dont want to have too much flex in the hull by cutting it all out together.
As long as the weather isnt too bad, i should have made a decent dent in it by the end of the week though i expect it to take twice as long as i have planned for as usual!
Il let you know how i get on
