Please help identify this boat
Discussion in 'Sailboats' started by Seafarer24, Aug 1, 2012.
  1. Seafarer24
    Likes: 2, Points: 18, Legacy Rep: 22
    Seafarer24 Sunset Chaser
    I searched all 24-26' designs on sailboatdata.com and still couldn't find anything that looked quite like this:
    The guy who lives on it is claiming that it is 25' long with a 10' beam and 6'2" headroom (likely only under the raised section of the cabin) and has two 40-gallon water tanks. Interior pictures show what looks like an enclosed head on the starboard side just forward of the step in the cabin-top. I also see a large hatch on the cockpit sole for engine access.
    Judging by the angle of the forestay and backstay the mast is retardedly short, and with only single side-stays it's not heavily rigged at all. Not sure if that is factory or what.
  2. Ike
    Likes: 501, Points: 113, Legacy Rep: 1669
    Ike Senior Member
    Looks home built or one off. Reminds me of a lot of ferro-cement boats I've seen.
  3. philSweet
    Likes: 567, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
  4. Seafarer24
    Current owner says it is an old timber boat... so I'm probably not interested anymore. I'm sick of finding rot in fiberglass boats, so a wooden boat just sounds like a nightmare to me.
  5. dan catalyst
    dan catalyst Junior Member
    you're from tampa too? I've seen this one,lol. hey, you might want to check out that westerly centuar in hudson for $1,700 on tampa c/l or sarasota maybe?. i almost picked it up,or that lecomte medalist mk1 for 2 grand floating in clearwater but listed in on miami c/l.
  6. frank smith
    Likes: 14, Points: 28, Legacy Rep: 185
    frank smith Senior Member
    With a built up top side.
    maybe ? .
  7. Seafarer24
    I'm starting to think that is an Eastward Ho 24, which was originally designed for wooden construction. Some of the measurements would be a bit off, but the owner could have mis-measured a bit.
  8. Tad
    Likes: 239, Points: 73, Legacy Rep: 2281
    Tad Boat Designer
    You never know if people actually confirm the measurements they put in ads or if they're just guessing or believed the previous owner.....
    An Eastward Ho has a beam of 8'8", draft is 3'10"......The rig in the picture is for assist purposes only.....
