the brain
Senior Member
- Joined
- Sep 3, 2016
- Messages
- 440
- Reaction score
- Location
- Alabama, home of college football champions
Please advise on prop. Selection an desired WOT RPM for a 2012 ETEC 175HP gen1.I believe 5850 (consulting experts bc I'm not sure.) is desired RPM so I'm currently leaving a few RPMs on the table.
200 /300RPM Discrepancy between WOT tacks. I think the Ray Marine is more accurate (which is higher) getting signal from EMM. or could OMC an Ray both interfer w/ each other?
Still image:
5500RPM at 41MPH OEM tack 5200 RPM trimed up so I'm leaving 350RPM on the table?
still image:Ray 4900 40MPH good water presure OEM tack 4700
video rear shot:
video rear shot moving alone good
moving along nicely is a fast cruise of 37MPH
video: engine shot: cav plate marked in pink, sking good trimmed down cav plate sking even higher w/ trimmed up so I think engine height is fine. note the pink marked tape started to peel off a bit creating some tabulate water.
Video see pink cav plate when trimmed up
Video link
video full throttle out the hole trimmed in/down RPM up to 6K bogged down but still got on plate just a tad slower image
then video
www.youtube.com
vessel is 1977 Starcraft Lake cruiser 22' w/ 24” setback engine pod
hull weight 1950LB by todays standards it would be classified as multi species type hull big aluminum hull.
2012 Evinrude ETEC 175HP 418LBs so basicely a litish vessel. Tests done w/ minimal gear.
A normal cruise add 50 gallons of fuel, 200LBs of gear.
prop. Being tested was OMC 391201 14.5x19 3-Blade RH w/ decent cupping, aluminum
seamed like lose of traction out the hole full throttle unknown why.
I'd like a tad bit more top end speed maybe 10MPH. Besides flooring it out the hole she'll usalley planes very quickly like if above 1500RPM (basicley moving slowly) then flooring instant on plane so bottom end seams good.
Please advise for a tad bit more top end speed
w/out scarificeing to much low end. thanks
Still image:
video rear shot:
Video link
then video
full throttle out the hole trimmed in bogged down RPM up to 6K
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
