plating, how not to
Discussion in 'Metal Boat Building' started by Guest62110524, Jun 16, 2009.
  1. MikeJohns
    MikeJohns Senior Member
    I think this technique of bow plating was in vogue for a while.
  2. Guest62110524
    Guest62110524 Previous Member
    tee hee, I once started a thread, Bueautiful Metal Boats, perhaps we should start The Ugliest Metal Boats, most would come from Australia
    Although that one has a nice enough entry albeit a wet ride in stiff bzeeze
  3. JeroenW
    Likes: 1, Points: 0, Legacy Rep: 30
    JeroenW Junior Member
    Defiance -> What's in a name ... :p
  4. wardd
    Likes: 37, Points: 0, Legacy Rep: 442
    wardd Senior Member
    it floats it cant be all bad but then i think liberty ships were beautiful
  5. Brent Swain
    Likes: 35, Points: 0, Legacy Rep: -12
    Brent Swain Member
    Vertical plating can create a huge increase in drag if it is not totally fair, as the water flows across the seams, rather than along them.
    A friend did an electronics job behind the iron curtain in the communist era. Some of the most beautiful women imaginable there made a beeline to the westerners and dropped their local boyfriends, as they saw a way out. Many of this crew came home with new brides.They obviously thought to so too.
    White South African women are so useless that they don't know how to boil a pot of water without burning it.
    Brent
  6. MikeJohns
    Brent
    In reality the drag is not that great, it will stimulate tubulent flow a little earlier on but it will make little difference with a long low aspect keel. Sometimes early turbulence prevents laminar separation and vorticity. With fluids it's never simple unfortunately unless you have high aspect foils, then you keep a nice attached flow across the foil and it had better be smooth and acurately manufactured to the design cross sectional shape too.
