Note: This feature may not be available in some browsers.
Sounds right to me, but he needs the shallow water drive capability of the (tidal) "flats" boats....and this is why he needs a flat bottom barge/jon, because it offers maximum displacement for his shallow water need
As another data point, the flat-bottom rig I've operated will run about 33 knots when empty, and around 27 knots when loaded with 3000lbs cargo. This is with a single 150hp Mercury four-stroke. There is a jackplate on the engine, but no tunnel on this rig. The jackplate adds six inches of setback, thus allowing the motor to run a couple inches higher while on plane.
If you decide on a tunnel, know that there are compromises. You will need a highly-cupped prop to deal with aerated water, and probably a four-blade design. You will lose most of your reverse thrust. Operation is a bit of a learning curve, determining what position to have the motor in and for what loads and conditions. Also, you will lose 3-4 knots top speed with the tunnel unless you design in a vent at the leading edge of the tunnel. The vent should be able to be closed. Run open for higher speeds, deeper prop, run closed for lower speeds and elevated prop in shoal waters.
Tunnel design is a complicated science. A cone will be very inefficient. Look at the tunnel design of Rescue Minor to get some ideas, as well as modern flats boats on the Texas gulf coast.
How is he gonna pull off a gravel bar with three four wheelers without a LOT of reverse?
